Boiler feed pump by Microcosm
Message par derekwarner_decoy le Dim 21 Avr 2013 - 1:31
KBIO.......I try again ....... 8)..........both of these links open for me from my message posting here .... :comprend pas Derek
http://www.ebay.co.uk/itm/Microcosm-M5-Steam-boiler-feed-pump-Twin-Cylinder-Steam-Engine-/151031060503?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D7105792403597557451%26pid%3D100011%26prg%3D1005%26rk%3D3%26sd%3D151025762118%26
http://www.ebay.co.uk/itm/Microcosm-M5-Steam-boiler-feed-pump-/151031061845?_trksid=p2047675.m1850&_trkparms=aid%3D222002%26algo%3DSIC.FIT%26ao%3D1%26asc%3D11%26meid%3D7105825690102791771%26pid%3D100011%26prg%3D1005%26rk%3D4%26sd%3D151025762118%26
It is a funny relationship being 6 mm bore x 5 mm hub.....but I have the small 12 Vdc geared motor @ 70 RPM & very low current draw....it also has a 4.0 mm diameter output shaft so will match the M4 pump eccentric  roi
I am sure that this combination will not make the  🔫  :hurle  noise of the Regner units........
derekwarner_decoy
