賛辞
賛辞
Message par Logoman le Lun 2 Jan 2012 - 17:09
Some of you will know of my like for the Japanese Saito V4PR, a small (9mm bore, 10mm stroke) single acting V4 piston valve marine engine.
Over the past year my friend and I have been working on replicating this engine, drawing it it up in Solidworks, machining it using the latest cnc machinery, and building jigs for various parts.
This has been a wonderful learning curve for me and the credit goes to my friend in this endeavor.
We decided to use the same materials; Stainless steel, brass and a very high quality phosphor bronze, but since we couldn't cast the engine block and cylinder heads as Saito did, we machined these,
copying the draft angles and then sand blast them to give a similar effect.
The three gaskets are .5mm gasket material, much better than the pvc  ones on the original.
The engine is about 10 grams heavier, as a result of using 2mm sheet for the rc lever (forward/reverse and throttle) and the valve links, rathere than the 1.6mm Saito used. I prefer the look of the these as they have square edges unlike the Saito ones which are pressed.
Where some fixings were blacked steel (which can rust) on the original, we have used stainless steel.
The engine is called 賛辞, which translates as 'Tribute'. This one will benefit from a little more running in, it has only been ran a couple of times, but we are very pleased with the result :D
Logoman
Re: 賛辞
Message par Logoman le Lun 2 Jan 2012 - 18:23
thank you Laurent.
best wished to you too, many happy moments besides the pond.
Logoman
Re: 賛辞
Message par Invité le Lun 2 Jan 2012 - 18:43
it's a nice work logoman applaudissement
Re: 賛辞
Message par GAZOU le Lun 2 Jan 2012 - 18:57
:cheers: SUPER !
Re: 賛辞
Message par KBIO le Mar 3 Jan 2012 - 19:46
:( INCREDIBLE!
On dirait le vrai!
This is smart and looks probably neater! :D bravo bravo
Un exemple de perfection dans l'usinage! bravo
Merci pour cette magnifique vidéo et ce non moins magnifique moteur qui va faire des envieux! rire 1
Je le verrai bien dans une chaloupe.............................. clin d\\\\'oeil
Bien cordialment! hello
Re: 賛辞
Message par Didier 94 le Mar 3 Jan 2012 - 23:25
:trin: Didier
Re: 賛辞
Message par Logoman le Ven 6 Jan 2012 - 0:18
Logoman
Re: 賛辞
Message par KBIO le Ven 6 Jan 2012 - 9:19
Good morning! :(
No swet! This guy knows how to use his lathe! bravo
Un usineur de première classe . C'est d'une douceur incroyable. Pas d'à coup et pas encore rodé!
Bravo pour cette réalisation .................................................qu'il faudra mettre dans un bateau! clin d\\\\'oeil
Re: 賛辞
Message par GAZOU le Ven 6 Jan 2012 - 9:32
:pleur
je pleure d'émotion, je suis admiratif ! ce moteur est une merveille bien plus belle à regarder que ma voisine.....Merci MICK
Re: 賛辞
Message par papeete le Ven 6 Jan 2012 - 9:50
Il est superbe ce moteur. Je suis sur le cu..l. :affraid: :affraid:
Merci pour ces vidéos bravo
Laurent.
papeete
Re: 賛辞
Message par Carlos Mariano le Ven 6 Jan 2012 - 11:34
applaudissement applaudissement Moteur superbe :( :(
Re: 賛辞
Message par Logoman le Lun 16 Jan 2012 - 22:30
many thanks for all your kind remarks :(
Logoman
Re: 賛辞
Message par Dave Gallagher le Mer 22 Fév 2012 - 5:26
Truly exquisite Miles. I have one too in the Opal and they are a joy. But this is a real jewel. Wonderful to see it in a model.
Dave
Dave Gallagher
Re: 賛辞
Message par papymouzot le Ven 23 Mar 2012 - 8:49
This is simply fantastic, incredible, beautiful, superb... I don't have enough vocabulary !!!
You can be really pleased with this engine, this is a piece of ART !!!
applaudissement
papymouzot
Re: 賛辞
