Vintage flash steam turbine
Message par Logoman le Mer 30 Nov 2011 - 21:58
Yesterday I had a few hours to spend photographing and inspecting the old flash steam turbine that may possibly have been built for a model of Turbinia judging by the shape of the funnel.
I would like to try and run this engine, but as all flash steam boilers are experimental, and model steam turbines remain problematic, usually needing very powerful boilers, I don't have high expectations. This is the only flash steam turbine I've seen.
Now I've worked out how to disassemble the plant, I can test the parts separately. I will try the burner first, as soon as I've a bicycle pump with the old style connector, so that I can pressurize the tank. I think it's a meths burner, since there was a feint meths smell in the tank. However I could be wrong, or it may have been filled with meths erroneously at some point.
with the boiler removed.
the turbine and water pump.
the boiler.
the ball joint on the prop shaft.
the socket for the prop shaft on the gear box.
I don't understand this part yet, it screws into the steam jet. I thought it was a to throttle the jet, but what is this hook holding?
I'll shoot some pictures of the rotor next time.
Logoman
Re: Vintage flash steam turbine
Message par GAZOU le Jeu 1 Déc 2011 - 5:09
quelqun peut t'il traduire ?
oui toi, en utilisant la fonction "traduire" dans la barre en haut sur ton écran. trinquons
Message par grosventre le Jeu 1 Déc 2011 - 17:52
Broaff !
Hier j'ai passé quelques heures à regarder ma vieille turbine à vapeur flash, dont j'ai pris les photos.
A en juger par la forme de la cheminée cette turbine à vapeur fut conçue pour réaliser une maquette de Turbinia.
J'aimerais bien faire fonctionner ce moteur, mais vu que toutes les turbines de ce type sont des protos, et que les modèles réduits de turbines à vapeur requièrent généralement des corps de chauffe très puissants, je ne sais pas trop quoi penser. C'est la seule turbine à vapeur flash que j'aie vue.
Là, j'ai regardé comment démonter les éléments, je peux étudier chacun d'eux séparément. J'essaierai le brûleur en prmier dès que j'ai une pompe à vélo avec un ancien raccord pour pressuriser le réservoir.
Je pense que c'est un brûleur à alcool car j'en ai reniflé des relents, à moins qu'il en ait été versé par erreur.
Message par Invité le Jeu 1 Déc 2011 - 18:38
:( bonsoir!
Encore une installation interessante et ancienne.J'espère que tu vas bientôt la remettre en état et nous faire une démonstration.
qu'est-ce qu'une maquette "TURBINIA" ? Un bateau??
Merci Grosventre pour cette excellente traduction! clin d\\\\'oeil
Bien cordialment! hello
Message par Logoman le Ven 2 Déc 2011 - 0:26
Turbinia
Logoman
Message par Malevthi le Ven 2 Déc 2011 - 8:37
Turbinia
Message par Didier 94 le Ven 2 Déc 2011 - 9:33
Belle bête !! bravo bravo
Message par Logoman le Mer 7 Déc 2011 - 13:23
Testing the burner on meths. I don't think it's the right fuel - it goes out as soon as the pressure comes up.
This time burning unleaded 95 RON petrol/gasoline
the burner has a needle valve which I have cleaned, but will try further cleaning. This valve is about 2 1/2" from the center of the dome.
The dome itself contains an arrangement of four vertical tubes that I assume open to the lower tray attached to the underside of the base plate.
Logoman
Message par Invité le Mer 7 Déc 2011 - 18:52
:( Bonsoir!
Interessant! La flamme est bien bleue et chaude.
On attend le résultat quand le bruleur sera 100%; clin d\\\\'oeil
Have a good time to overhaul all!
Cheers! trinquons hello
Message par papymouzot le Ven 23 Mar 2012 - 8:34
Plus de nouvelles sur ce post très intéressant ? Je viens de le découvrir, et ça ressemble vraiment à ce que j'avais en tête 8) J'adore ce look "vintage" !!!! :D
Logoman, please, give us more news about your investigations about this old flash team turbine.... please !!! :biz
papymouzot
Message par GAZOU le Ven 23 Mar 2012 - 8:45
:affraid:
tu parles ! va bien réussir à foutre le feu à mon ordinateur avec son machin !
