New project
New project
Message par steamup le Mer 18 Juin 2014 - 23:34
This is the model I am working on at the moment power will be via the MB22 Paddleducks engine built from the site of the same name.
steamup
Re: New project
Message par marcovi le Jeu 19 Juin 2014 - 2:52
Fantastic project
I love the line of the boat
Press to see the progress
Sincerelys
Marc
marcovi
Re: New project
Message par steamup le Jeu 19 Juin 2014 - 18:19
This is a short video of the engine running on air
steamup
Re: New project
Message par KBIO le Jeu 19 Juin 2014 - 18:33
hello Hello!
It sounds fine to me. oui
I love your launch! Very uncommon by the shape and the rudder! génial
Cheers.
ps: do you still have problems to insert photos??
Re: New project
Message par steamup le Jeu 19 Juin 2014 - 18:49
Try this one:
steamup
Re: New project
Message par KBIO le Jeu 19 Juin 2014 - 19:57
applaudissement génial
Re: New project
Message par jacky241 le Jeu 19 Juin 2014 - 23:23
un chinois qui chaufferai au charbon de préférence !!
apparemment pas de confrères outre manche pour l'instant.
Re: New project
Message par steamup le Mar 8 Juil 2014 - 0:38
Some progress on the steam plant
steamup
Re: New project
Message par KBIO le Mar 8 Juil 2014 - 8:44
bonjour Hello!
Lovely! génial
It looks like it wont be long before we see everything running on the pond! oui
Cheers. bye
Re: New project
Message par pif. le Mar 8 Juil 2014 - 8:51
bonjour Hello !
I like the rear of the cant with are rudder type "Admiral KITCHEN"  génial
A beautiful set steam  applaudissement
Re: New project
Message par steamup le Mar 8 Juil 2014 - 23:20
steamup
Re: New project
Message par KBIO le Mer 9 Juil 2014 - 11:36
hello Hello!
 génial Progressing on this nice setting.
But the glass of wine has disapeared. Must be empty! triste
Cheers! trinquons
Re: New project
Message par steamup le Mar 15 Juil 2014 - 19:47
This is the feed pump mechanism I have been working on:
steamup
Re: New project
Message par KBIO le Mer 16 Juil 2014 - 8:36
hello Hello!
Nice setting, working good!
The video does not allow to see it all, but, is the height of the priming , low enough??
Cheers?
Re: New project
Message par steamup le Mer 16 Juil 2014 - 13:19
The mechanism will be in the seating with the water tank slightly higher in the bow.
This should provide for gravity feed to prime the pump.
steamup
Re: New project
Message par steamup le Lun 21 Juil 2014 - 23:51
This is the second effort at making a prop the first went well the second well best not say too much all was well in the end lol!
steamup
Re: New project
Message par KBIO le Mar 22 Juil 2014 - 8:58
:hello:Hello!
The result is OK!
It would be interesting to know which one has the best performances.
Cheers.
Re: New project
Message par steamup le Jeu 24 Juil 2014 - 16:02
First sea trial a little water came in. Ballast not required at the moment I think.
steamup
Re: New project
Message par KBIO le Jeu 24 Juil 2014 - 19:58
hello Hello Steamup.
Mint condition! génial
You see when you sail if you need some weight. But as long as the propeller stays under water, you better keep light. oui
Waiting on next pics.
Cheers. bye
Re: New project
Message par steamup le Jeu 28 Aoû 2014 - 1:22
Getting closer to the first sail. One or two steam leaks to fix.
steamup
Re: New project
Message par KBIO le Jeu 28 Aoû 2014 - 8:50
I thought that you run this machine with steam already??
Fixing the leak will obviously increase the output. But it runs fine so far.
What is the next step?
I definitvly love your launch.
Cheers! bonjour
Re: New project
Message par steamup le Ven 29 Aoû 2014 - 1:07
I tried it on steam made alterations then lost the timing face à l\'ordi .
After much head scratching I manged to sort the problem out. I think the engine will need some running in ,it is already showing improved running after a couple of steam ups.
steamup
Re: New project
Message par pif. le Ven 29 Aoû 2014 - 7:30
bonjour Hello;
Bah, leaks these art of mechanics, and wandering steam lubricates the mechanical mondieu
génial Kind regards
Re: New project
Message par steamup le Sam 30 Aoû 2014 - 12:35
This is after a few changes to the engine.
steamup
Re: New project
